Q400 Throttletek Unit + Training Edition
Hello dears,
i struggle to calibrate several detents on both throttle axis and on the flaps axis via the jconf tool…I managed to calibrate the parking brake, control lock and the ga button! Is there someone who could help me out with calibrating the detents on the throttles and flaps?
Brgds Ben
  • edited December 2021
    Hi Bolzen1988,
    You assign the axis' of the throttle and condition levers via the joystick connector app, then you use the Q400 control panel to set the various detents the same as with the Pro edition.
  • Hi Jax_in_BC,
    yes i did that, the only thing i struggle with is the flaps axis, because when i assign the flap lever via the connector app, as soon as i select flaps 5, it will go dow all the way to flaps 35…I think i saw a post here in the forum where someone had the same issue…Is there a way to assign the flap detents somehow?!
    Brgds Ben
  • There is no way to assign flaps detents. As an alternative, you could use a flight simulator own flaps axis, in which case you will be able to use the sensitivity and null zone setting of the flight simulator
