FMC
Hi, we try to download updates from Navigraph into the same folder where we installed Q400 in P3Dv5. But it will not install. Any trick to get the FMC updatet? Q400 is excellent in so many ways but this is really a problem.
Check your six/Carl
    Check your six/Carl
    Hi, I use Navigraph navdata as well, and I simply use the FMS Data Manager provided by Navigraph to update the navdata. Simply add the majestic Q400's path into the FMS data manager and then click update to get the latest AIRAC.
