Taxi and landing lights are too bright
Hi all,
I'm using P3D v4.5HF3 and MJCQ400 Pro Edition last release. I'm not using the Visual Enhancement Pack.
I usually fly during the daytime but I made a leg during the nighttime and I noticed that the taxis and the landing lights are too bright and cause reflections on all surfaces (buildings, runway, signals) that are really unrealistic and annoying. I did some testing and saw that this problem only exists with the Dynamic Lighting option enabled. Other aircraft do not have this problem and it is independent of the type of scenario used (stock, freeware, payware).
Is there anything I can change in the configuration of the Q400 or P3D?
Thanks in advance for the support.
Alessandro
