Landing lights ON causes stutters
I've noticed that when I switch the landing lights to ON it causes some stutters... is there any way to fix this? Its really sad...
Im using v5.3 with Visual Extension Pack.
Than you!
  • Just saying that you are getting stutters without any substantiating information does not allow one to be of much help. If I recall this has not been one of the reported issues wit the Visual Extension. Is this happening every time you turn the lights on, and can you provide times where it is noticeable so that tests can be conducted
    Than you!
    What do you mean by stutters? Do the lights flicker/stutter? Or does your sim stutter, aka FPS drops? I have the training edition of the q400, and am running p3d v5.3, with latest hotfixes, and I noticed the lights would flicker and create black squares. Once I rolled back my Nvidia GPU's driver back to the previous iteration, the problems went away. Maybe this will help you
