Navigraph data
I periodically update navigraph data but certainly not every airac cycle. When using the Garmin G1000 for example I check important data like ils freq against the current approach chart in case there are differences. So far I have not been able to find a way to check what data is in the Q400 database. Can this be done with the FMS ?
  • I dont know whether its helpful: Start the FMS, run selftest and then on Page Init 1/1 you find "Standard/Extended NAV Database expires (Date)". So you know the date of the last update.
  • That would have some value but it still will not tell me what the localizer frequency is for the runway I'm using to land. I would assume if I input the localizer frequency from a current approach chart and it was different from what was in the fms database then I would get some kind of error message. Normally, what I would do is input the setting in the database, but to do that you have to know what is in the database.
