dash8 pro with LNAV Problems
Hi there,
my dash does not comply with the heading and lies diagonally in the air.
What`s the problem?
Any idea and help is welcome
Thx
Dieter
Hi there,
What`s the problem?
Thx
Dieter
First of all, turn on the de-icing system since you seem to be iced over, second of all check your rudder and ailerons trim and make sure they are set correctly. If that doesn't help re-install the aircraft.
OK that works!!
many thanks
Welcome!
