125HZ Smooth
I have a real problem trying to confg my Ch throttel Quad thru Chris Hume Majestic 125Hz Control Cfg since the last Win 10 update.I get two readyings instead of one they are X 2193-65535 and Y 1419-65535 using throttle 1& 2.I have tried uninstalling and reinstalling several times my CH control panel as well as my Ch yoke rudder and throttle. Is there a fix for this problem..................Regards Robin
  • Just to make it more clear throttle 1 comes up as X axis and throttle 2 comes up as axiz y . So how can you obtain 125hz setting when you have two readings for the same throttel hardware............robin
