125HZ Smooth and USB Hub
I'm going to buy a usb hub and want to fing out: does a usb hub affect the 125HZ Smooth feature?
Of course not.
and really no lags significant for the aspect?
I'm using a USB hub and it works just as it should. The data transfer rate needed for the FCS is minimal so USB's should not bottleneck it in any way.
Very well, thank you a lot for the explanation!
