Key command syntax question - AP engage
edited November 2018 in General
Hi all,
Trying to map a key command for the autopilot engage. In the variables list I see the command I'm after is
AFCS_->inputs.mode_button
with a list of sub variables in the comments field that include AFCS_KEY_AP 11
My question is how do I format this command with the number 11 sub variable?
  • Hi all, just bumping this. Anyone able to assist? Thanks in advance!
  • Not sure but I have mine maped for the AP disengage liek this:
    J1_b1=AFCS_->inputs.AP_disengage
    J1 being my joytick number and b1 being its button.
  • Thanks Bravomike, that's the AP disengage command, and I already have that one, but I appreciate the help.
    What I'm looking for is the AP engage command, which is documented as per my original post, but the exact syntax to use it is not, at lest not anywhere I can see.
    Mark
