Hydrollic light on engine 2 panel. [RESOLVED BY USER]
This was my first time flying mjc q400 since I moved from fsx:se to p3d 4.5, and upgrading to mjc pro fsx to p3d 4 mjc pro. I started with cold n dark. After loading the plane I turned on the master battery switch, then the hdy light on #2 engine overhead panel started flashing between on and off. It should be off. Nothing I did could stop it. I've restarted several time, but no luck.
I meant hydraulic. However, I started up today and both engines on the overhead panel had the hyd open/close lights flashing back and forth with the caution light coming on and off. This was after turning on the master battery. Later today I'm going to try loading with boarding as the startup. If that doesn't work I guess I'll do a reinstall.
I ended up reinstalling and it works now. Must of had a hiccup.
