Uninstall question [RESOLVED]
What is preferred method of uninstalling the Q400 Pro ? I may need to uninstall / reinstall the Q400
in hopes of fixing some issues (Tiller inop, etc).
My software is Win 7-64 and FSX Acceleration.
Will the reinstallation install a fresh MJC Q400 Control Panel also?
Thank you,
Ken
  • You can uninstall the Q400 via the Windows "programs & features" menu.
    Re: the control panel, will get re-installed as well. make certain to right click on the installer and select "run as administrator. You may want to temporarily disable your anti-virus software before installing, as well.
  • As far as I know, the "usual" way of using the programs and features thingy is completely clean. Done it multiple times, and there should be no files untouched.
  • Many thanks for the fast and informative replies.
    Best regards,
    Ken
