Fuel Loading
Hi, I have the Q400 1.02 installed on P3Dv4.5, Win 10 Pro (all updates installed).
I calculate the fuel I need (NZWR - NZWN) at 5631 lbs. Using the Control Panel I load the Fuel, Pax and Cargo. For some reason once the Fuel is loaded and I turn off the Pause, within 1 min both the aircraft and P3D reset the fuel to 100% (11712 lbs).
Is there something else I need to do? Or is this an issue with 4.5?
Harry
  • Are you standing near a fuel pump? That always used to reset my fuel to 100%.
