Pax Weights issue
The MJC control panel has a weird glitch with the pax weights. Every time you add a passenger above 1 it adds that much weight. For example the pax weight is 186 but if i add two pax it should be 186+186=372 but the control panel outputs 373. And if you add three passengers 186+186+186=558 however the MJC adds two pounds for this. and so on which causes a huge issue when loading way more passengers and most importantly its a problem for simbrief and PFPX. Can anybody shed light on this?
