q400 Pro update
I loaded the Pro update 1.020b and it appears to have worked ok. I'd like to check that I have the proper version but have no idea where I can check. The only place I looked which indicates a version is the document index page, which now says 1.020, missing the "b".
Dasher
  • I think there is a note in the FMC, as with some other aircraft, there is not, but in the Aircraft Majestics folder there is a text file after the installation with information about the version and the changes made.
