Nose Wheel Steering Problem
I had to reinstall the Q400 Pro after the latest update made it unusable.
I reinstalled without the patches and now I cannot get the nose wheel steering to work with the "mouse and aileron" option selected.
I do not use FSUIPC and I calibrated the inputs with the control panel. Flight controls and engine controls are set and work as designed. I can use the tiller with the mouse, but not with the ailerons. I selected the option within the control panel with the Q400 loaded, pressed Apply and reloaded the aircraft, but no luck.
Any ideas what I could try?
Thank you!
