1020b still issues
Hi
A few things to take note of:
I only have one complex aircraft and that is the Majestic Q400.
I have flown the Pro-version without any issues since 2018. Today I decided to do the 1020b patch update and now I got issues. (See images).
Went to another post that talked about problems with the new patch. Tried every fix suggested. No luck.
..At first load (from default scenario) I cannot push any button and simulator is paused immediately (forcing me to unpause it every time). After I reloaded aircraft (if I dont get any CTDs), some buttons will be operable and some not. I cannot start the CDU etc.
UPDATE:
Silly me, I had simply not updated Prepar3D to V4.5. Once I did that, airplane worked flawlessly!
Problem solved!
