Nav Data Issue
Hello!
I fly this great add-on in East-Asia region.
I found that the FMS works perfect for flight, with the ability of DME arc, holding, offset etc.
But I also found that some procedures(SIDs,STARs, approaches) are missing, or with correct ones, some transitions are.
For instance, in RKPK(Gimhae int'l airport), SIDs consist of BETTA2, GARAK3, LEEMA2, SOORO1 , and GIMHAE2 for runway 36L/R departure.
However, in the Q400 FMS, it shows only BETTA2 and GIMHAE2 departure.
And, in BETTA2 departure , there are many transitions (KALOD,MASTA..etc) according to the chart.
The FMS shows no transitions above.
Other addon aircraft I use show everything correctly.
I think this is Navigraph-issue, even if I downloaded AIRAC successfully with FMS data manager.
I'm gonna post the same in navigraph forum, if can't solve this.
Any ideas for resolution?
Thank you.
  • I use AIRAC 1913 and it support all procedures I described above.
  • Where the departures are not runway specific such as GARAK3 RKPK then DO NOT select a runway in the FMS, go directly to the SID
  • OK , I solved it right now! Thank you for help :)
