Is someone can use GoFlight module with Q400 like GF-46 for radio frequency changes ?
Hi all,
Has someone been able to configure certain Goflight modules like the GF-46 in order to be able to modify the radio frequencies?
I use FSUIPC to configure several buttons and switches.
Christian
It's possible. But it means programming in LUA. And you have to use the XML interface provided by Majestic.
where to get the XML interface?
Dresi
Check your aircraft folder for the documentation. You will find everything there.
