Navdatapro with q400
A few days ago bought Navdatapro and tried to update the airac cycle. With the Airbus it worked perfect but when I tried to update the dash, Navdatapro said: Installed: not found.
Can you help me?
Regards Martin
  • Information I use FSX and tried to use other paths in Navdatapro
  • Well, the path for the FSX is if it cannot be found by itself (path to the FSX as it is with you)
    FSX / Sim Objects / Airplanes / mjc8q400 / nav
  • Thank you it worked!!!!!!!!
