How to get announcements for a specific livery Q400 pro
I would like to know how to get announcements for a specific livery, for example for JZA?
I copied the sound \ announcement directory in the JZA texture directory by modifying one of the WAV files but it seems that the default file is executed.
What is the exact directory structure required?
thank you
Christian
  • edited July 2020
    Hi @cridel on folder SimObjects\Airplanes\mjc8q400\sound\announcement\make folder called ''JZA'' put the sound from the default to JZA
    Then go to directory in the JZA texture and make folder called ''announcement'' and copy and put the announcements.mgs from default livery texture.
    **Modify the announcements.mgs with notepad
    and give the directory of the sound **SimObjects\Airplanes\mjc8q400\sound\announcement\JZA **
    I will give you my photos below to see exactly.
    https://prnt.sc/tbr7ka
    https://prnt.sc/tbr7yl
    https://prnt.sc/tbr8ae
    https://prnt.sc/tbr8lp
  • Tanks Sir, I'll try this ASAP
    Christian
  • Hi Andrew,
    It works well with your procedure. However, the sound is weak for the recordings I made. I used the same parameters as the original sounds. Perhaps it is the volume of my microphone during recording that is low. I will redo tests with headphones.
    Christian
  • Sorry....thank you vasilishal
  • @cridel you are welcome.Also at the mjc84.ini you can increase the volume of the announcement
  • Thanks, will try it.
    Christian
