Aircraft flying at an angle in light winds
I noticed the aircraft is always flying at a slight bank even in light winds. Is this normal?
Hi, rudder trim is your friend...
... and this trim will accompany you from the takeoff to the final approach for the whole flight, because when you change direction and change the power settings, you may have to trim again.
Five clicks Right trim as part of your pre-flight. Constant retrim during flight and decent.
