Propeller beta range lights
Hi.
Someone can give me more infos about this light ?
    As you have obviously a lot of questions, please check the documents on this website:
    https://smartcockpit.com/plane/BOMBARDIER/DASH-8-400.html
    Furthermore there is a DOC folder in your aircraft directory, where you find excellent documentation provided by Majestic.
    If you read through these documents you will find a lot of answers to your questions.
  • Basically the numbers (1 and 2) display when the coinciding prop is in the beta range (below flight idle). So if the number 1 prop is in the beta range, the number 1 will light up, etc.
