Reduced rudder deflection
Hello all, I have quite a problem with rudder deflection - despite proper configuration in control panel and FSUIPC showing that rudder deflects normally I'm not able to set it to its full left and right position as it stops in aroud 50% of the way. What is interesting pedals in VC looks to move normally (to full position)
http://oi63.tinypic.com/2poz588.jpg
http://oi68.tinypic.com/ofdm36.jpg
I'll be grateful for help.
  • A rudder input restriction mechanism, limits pedal travel with flap selector lever position. The flap selector lever is mechanically linked to the co-pilot's rudder forward quadrant. with 0° flap selected, pushing either rudder pedal to the stops, deflects the fore rudder surface 12° left or right of center. With flaps selected to 5 or greater, pushing either rudder pedal to the stops, deflects the fore rudder 18° left or right of center.
  • Thank you for explanation!
