Uninstall question [RESOLVED]
What is preferred method of uninstalling the Q400 Pro ? I may need to uninstall / reinstall the Q400
in hopes of fixing some issues (Tiller inop, etc).
My software is Win 7-64 and FSX Acceleration.
Will the reinstallation install a fresh MJC Q400 Control Panel also?
Thank you,
Ken
You can uninstall the Q400 via the Windows "programs & features" menu.
Re: the control panel, will get re-installed as well. make certain to right click on the installer and select "run as administrator. You may want to temporarily disable your anti-virus software before installing, as well.
As far as I know, the "usual" way of using the programs and features thingy is completely clean. Done it multiple times, and there should be no files untouched.
Many thanks for the fast and informative replies.
Best regards,
Ken
