FMS NAV DATA UPLOAD
I am unable to upload a SimBrief saved nav file into my FMS.
I have manually checked the nav/routes folder and the file is saved there.
I am also running AS for P3D4.5 if that's of any consequence.
Can anyone assist.
John Proudlock
Hello John,
I have not used simbriefs upload feature recently but it should work. I would suggest reaching out to simbrief for assistance if needed.
The question is are you attempting to recall the FP correctly via the FMS?
I had no problem with it. ; Also running AS with v4
Use Simbrief and the Q400 every flight. Always works perfectly.
