Remove Hud
I've loaded the Fedex repaint into my P3D v4.5 , Q400 Pro (for P3D). I'd like to remove the HUD and in the past, on my old computer, I did so. I can remove the HUD on the default Majestic 400's using the Config Panel, but the cargo repaint is not so easy. I am thinking the individual config needs editing but really I can't remember what I did. Remembering that the freight model needs a freight module folder, which I have.
Can anyone direct me please?
Dasher
  • I found the cure. Edit the panel config file to noHud. It's easy because there are only a small number of lines, so error is unlikely.
    dasher
