APU won't power on
I have a problem when pressing the PWR-button on APU Control-panel, the buttons goes flickering (self test?) and then nothing happends. Suddenly after several attempts and maybe 20-30 minutes the Fuel valve is suddenly opening when pressing PWRm and the rest of the procedure can start.
Any help?
To help you understand, you press the APU PWR switch, it obviously takes the self-test (all the switches there with their lights light up briefly in a cycle), but the APU fuel valve stays closed (white light) in the Fire Protection Control Panel? It should actually light up the green lamp for open.
The green lamp dosen't turn on. That's my problem![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
Hope this isn't a silly question but.... after pressing PWR and self test completes, do you then press START? The PWR button doesn't make the APU start.
Proud supporter of http://www.ViaIntercity.com, 950+ flights for J41 & Q400 and 200+ for A320
Also, are you in the air when doing this?
bravomike makes a good point, Q400 APU is not rated for use whilst airborne, if there's no weight on the wheels, the APU will not start.
