Sound Loss
I had an issue with the sound on my pro version stopping completely after about 15 minutes or so. Restoration required a restart. I traced this to the option in the control panel that directs some sounds to the headset. If this option is unticked the problem never occurs. I now fly with this unticked but have never solved the issue. I thought this might help anyone else who experiences this problem as it does make the plane otherwise useable. If anyone has a solution I would be interested.
Mike
Windows10. i7. r290x. 2xDell u2414h.
Thank you for the heads up Mike, much appreciated
