Undercarrage Fire
Hi
I have see screenshots of the Dash 8 400 with the Undercarrage on Fire.
Is this failure only on the training version?
Thanks for reading
Bart.
  • Mostly yes primarily for the TRAINING EDITION. However one can create their own script for engine fires/failures etc.
  • My Dash was on fire after the FSX started, but I didn't do anything about it. I couldn't explain that either.
    Pretty sure that's just a thing that can happen when the default failures ini gets initialized, happened to me, too after loading the MJC8 for the first time after upgrading to pro.
  • There are odd occasions where that can happen. We have encountered it a few times during extensive testing, but have seen it more often when a complex aircraft was selected prior to loading the Q400. For best results, attempt to load a default aircraft with FSX or P3D, and then load the Q400.
