Abnormal Checklist
Where can I find the abnormal procedures checklist for the mjc84?
  • Probably not with Majestics. There was once a download link from a member here. His nickname is bazaranet. In the u.a. contained in the AOM are the Abnormal and Emergency Procedures. Unfortunately, the data volume is too large to be set in this way.
  • What version of the Q400 do you have? If you own the pro version then one has been supplied which is located in the docs folder of the mjc8q400 root folder. You can simply click on the html link and there are various manuals from which to choose.
  • That's it!
    Thank you very much. :)
