Latest installer v1.021 and reports from ContentErrors
From the ContentErrors of p3dv5
[error.13]
error=Failed to load visual effect "mjc_prop_flash_right_appr"
[error.14]
error=Failed to load visual effect "mjc_prop_flash_left_appr"
[error.15]
error=Failed to load visual effect "mjc_prop_flash_left_flare"
[error.16]
error=Failed to load visual effect "mjc_prop_flash_left_apprflare"
[error.17]
error=Failed to load visual effect "mjc_prop_flash_right_flare"
[error.18]
error=Failed to load visual effect "mjc_prop_flash_right_apprflare"
[error.19]
[error.20]
[error.21]
[error.22]
[error.23]
[error.24]
[error.25]
[error.26]
[error.27]
[error.28]
[error.29]
[error.30]
[error.31]
[error.32]
[error.33]
[error.34]
[error.35]
[error.36]
[error.37]
[error.38]
[error.39]
[error.40]
[error.41]
[error.42]
[error.43]
error=Failed to load visual effect "mjc_cockpit_smoke"
[error.44]
[error.45]
[error.46]
[error.47]
[error.48]
[error.49]
Is it affecting the operation of the aircraft?
Thank you for sharing this information with us. The effects are not included, as they are no longer needed with new dynamic lights we have implemented. The next patch will address the issue of the sim logging this error
No..... guys the aircraft works perfect just for information!!!!
We know the aircraft works, but as always thanks for the update.
Thanks alot for this amazing work anyway.
