Bouncing Dash8 upon loading into P3D
The newly updated Dash 8 bounces every few seconds when loaded into my P3D4.5 (latest HF). Tried default scenery and addon-scenery. Any ideas?
Previously discussed tipic:
http://majesticsoftware.com/forums/discussion/comment/1226#Comment_1226
Yes I read that thread and tried the suggestions to no avail. I thought it might be beneficial to open a new one as this didn’t happen in 1.020 version. Any other suggestions? I’ll try a reinstall in the meantime.
Ross
What type of bounce is it?
One that leaps several feet in the air, or every few minutes the aircraft performs like a hop?
I had the same problem and it got solved with the Taxi Speed fix in EZCA. In case someone is using it.
