CTD when using FMS
I haven't flown the Q400 in a while but recently returned to it in P3D 4.5 HF3. I have experienced several CTDs when operating the FMS pop-up window. Specifically, it appears to happen if I click on functions like cross-filling between the two FMS, loading a flight plan etc. P3D then immediately stops and closes.
I never had issues with the plane before, but the last time I used it was before I installed HF3. Is the plane compatible with HF3? Below you may find the event viewer log from Windows 10.
Thanks,
Peter
Faulting application name: Prepar3D.exe, version: 4.5.14.34698, time stamp: 0x5e94b5c2
Faulting module name: mjc84_main.dll, version: 1.0.0.0, time stamp: 0x5a1325d7
Exception code: 0xc0000409
Fault offset: 0x00000000003606ac
Faulting process ID: 0x3a84
Faulting application start time: 0x01d6374c83014cc7
Faulting application path:
\P3D4\Prepar3D.exe
Faulting module path:
\P3D4\SimObjects\Airplanes\mjc8q400\panel\mjc84_main.dll
Report ID: ead50ad0-142a-486b-8507-ce007be29724
Faulting package full name:
Thank you for your report. As this seem to be an isolated issue, could you please contact support@majesticsoftware.com ?
I have reinstalled the airplane and that seemed to help. I will report if it happens again.
Peter
Thanks for reporting back
