Suggestions for Q400 Enhancements
Fellow Airmen,
The Q400 has been an operator in the virtual skies for over 7 years, and while we continuously work to improve the product we thought it would be a good idea to reach out to the community to get a feel for what possible enhancements you would like to see added to the Q400.
I'll give it a kickstart:
- True Glass rain effects
- PBR
- FMS functionality
While we can not guarantee that all requests will be granted we will certainly make a thorough analysis and see which ones are practically feasible.
We will leave this thread open for TWO WEEKS.
Most airplane lovers are aware that the dry operating mass varies from aircraft to aircraft, among the same type.
My suggestion would be; having the possibility of having the DOM of an "individual" aircraft, being saved in an ini file according to the airline texture in use. Similar to what is being done with the maintenance states and times, already.
Oh, and maybe the fuel remaining after a flight is completed or the sim is shutdown after a session.
Cheers, Jax
Allowing the user to change the DOM would also require you to have the DOI. We ahve discussed this in the past, will have to see how we can implement this.
So in essence, the livery that you are currently flying, the remaining fuel state would be reloaded the next time the aircraft is used.
Yes. It's a bit of a selfish request, as I sometimes like to do multiple legs using a particular airline routing, and am often called away before I can complete said legs.
It's the giant nerd I have inside. Thanks for the response, Kroswynd. Stay safe.
Jax
Here would be my suggestions, from a maintenance guy point of view
1- Slight parameters variations between LH and RH engines. Typically, for the same torque/rpm, you will often have one engine showing a little higher NH, ITT and fuel flow. Oil parameters are also slightly different.
Operationally, engines changes/swaps happen relatively often on a given airframe. So it is common to have engines that don't have the same age, generating further parameters difference (an older/more worn engine will require more fuel and show higher ITT/NH to achieve a given thrust)
2- GSX integration (automatic opening/closing of doors, refueling)
3- weight and balance import from simbrief flight plan
(remove the need to manually specify number of pax and luggage in each area)
Thanks!
Updated Virtual Cockpit panel textures. More sharp
PBR Outside.
More GSX Integration
Windscreen water effects (But hopefully not using TrueGlass as it is unstable)
Snow on outside of airplane.
That's my vote
It would be nice to see an updated MTOP button logic. In the real Q400 MTOp is deselected by pressing the MTOP button again, whereas in the MJC Q400 MTOP disappears after a few seconds by itself.
Another nice feature would be a steep approach button, as the EGPWS in normal mode is quite annoying during steep approaches.
Thank you!
I am building my own dash8 q400 home cockpit, I noticed that there is no possibility of having the 2 PFDs and MFDs unlocked simultaneously in 2d, moreover what MUCH more important, (I'm running into it these days) in such a program valid it would be advisable to have all the variables of the annunciator panel (I know there are many, about 98) to have the possibility of building the announciator panel as the real one, with single lights, also because given the position of the overhead it is impossible to put a second monitor to unlock the announciator panel in 2d and use it via monitor.
thanks.
I sincerely hope. Concentrate on creating the training edition first!
Thanks!
Not shure if it's not too much work but maybe EFB?
PBR inside and out
Updated FMS version
EFB with takeoff/landing perf app + loadsheet abiltiy to just set ZFW in payload manager.
Integration with PMDG Flight Operstions
Interior and Exterior PBR Textures
LPV
Interior shadow model (so you see the external model casting a shadow from the cockpit).
EFB (for navigraph charts and performance).
Apart from that maybe higher rez. textures and then we are good to go.
But regarding the beloved mighty Q400, here’s my contribution to the suggestion box:
1. An EFB would be neat
2. More GSX integration I guess
3. Something about the friction with the nose wheel steering needs some updating In my opinion (heavy tiller input at high speeds seems too easy to accomplish)
4. Effectiveness of “MAX REV” on deceleration
5. A livery manager would be a great addition to the CPAN
6. TrueGlass and PBR
7. Updated cabin announcements to match the airline name, destination and “estimated time enroute”
8. I still think the engine sounds are not the best best, but a third party team did some better ones so duces
9. Inclusion of airframe option would be fun, similar to PMDG’s work with the 737 (Might be more suited to Q300) (lights, avionics, etc).
10. Lastly, some general touching up on cleaner and sharper textures etc
Thank you for producing such as an amazing product, and ofc, TurboProps rule 💪🏼
Please, do not include trueglass. I rather preffer do not have rain in vc than to get a thousands of CTD's an continues delays on compatibility platform updates because trueglass. Is not an option the vcrain from A2A? I think is free for 3ds parties.
I love the Dash! I love your work!
Keep up!
Richard
I would love to see the following version in the sim:
Bombardier Q400 NextGen
Thanks for all you guys do.
EFB with performance calculations is a must
Agree on the EFB for performance and sending weights to the aircraft if possible.
-Wind uplink for the FMS, not sure if thats part of the enhanced FMS functions.
-HD textures for inside and outside.
-A bit more of GSX integration.
-CPDLC/ACARS
Still impressed by this ac after 7 years, always a joy to fly
EFB w/ W&B and Take-Off/Landing Calculator...Navigraph w/ chart integration would be a nice treat too.
Thanks for this open brainstorming.
What about a detent (like a small dead zone) or at least a sound in throttle when you reach the Flight Idle detent, preventing you to go too far back when airborne and entering "beta" mode?
The icing logic seems a bit exagerated as well. There is a lot of clear sky icing in my opinion.
Still it remains a damn excellent simulated aircraft. Thanks guys.
It doesn't even take an EFB to do the performance calculations. On Air Canada Jazz (and I'm sure even more carriers), pilots send a perfomance request using the FMS, and then receive a performance report. That would indeed be fantastic to have.
I have one more thing to say.
Please add function of cabin configuration customization.
With it, We can fly with Q400 as Q400CC(CARGO COMBI) and simulate various airlines.
On system panel, for the called "instructor mode", some addition to fail other system types, like pressurization, to be possible to simulate an emergency descent.
Would love to see like the images above - ACARs functionality with perf and other data implemented like the FSLabs stuff. Very realistic.
agree. With pushover support like the md80 and fslabs also
Thank you for the suggestion, however why would you need to calculate individual crossing altitudes ? If the FMS VNAV does not have information on the waypoints it overflies, it will calculate it's altitudes automatically
Both functions should work, please provide an example of the procesure (transition). Also would be good to have some info on when the FMS fail to syncronize, for us to verify it.
Hi, Boss.
As far as I know, this issue affects almost all SIDs with ENROUTE TRANSITION.
Example:
Check the KLAS BOACH8 DEPERTURE with TNP TRANSITION.
With Runway selection(RW08L...etc), We can't select TNP TRANSITION and can only choose the route to BOACH.
The issue has been confirmed by several people.
In addition, I'm talking about FMS1 & FMS2 synchronization supported by FMS version 1000. I'm not talking about a bug.
@Boss
Please check following link.
FMS Bug
FMS SID STAR LOGIC
http://majesticsoftware.com/forums/discussion/468/fms-sid-star-logic
FMS1 & FMS2 Sync.
FMS System Update forseen?
http://majesticsoftware.com/forums/discussion/946/fms-system-update-forseen
I have not yet fully understood what is being criticized here. In many flights I did not see any problem in this regard, i.e. maintaining a vertical profile. Restrictions were observed, and the VS was adjusted if necessary. The same happens with fluctuations in speed, which was also compensated for by changing the VS. So far I have sunk to the FAF / FAP without any problems and the subsequent RNAV GPS approach using VNAV went just as smoothly. Would be really nice to see what works even better in the real Dash.
I got the Q400 since the beginning and even that I flew RW before it took me a long time to understand the logic, or should I say illogic, of that particular plane.
Anyway I love her and I do not fly anything else.
We all would like some extra features and I understand that it is not easy to implement everything.
Anyway I would love:
Regarding the EFB, I think the Navigraph one is working with the Q400 but as far as I am concerned, getting a bit old now, I still prefer the old paper charts.
Just a bit off topic, but as mentioned Struggle Crow in a post above:
This is true and a bit ennoying but is it only with the Q400 or is it a problem with the data provider?
Santa can land in my garden with his Q400 equipped with some new features, he would be more than welcome..
I’ll echo some of the points above first and then add my own:
Fix the SID/STAR runway transition issue. I have experienced this as well, coming out of LAS is a good example.
Slightly different engine parameters
EFB / performance calc. Would love to see takeoff &landing distances included
Just an idea, but not a necessity: MJC has provided a Q400F model, can the W&B section of the System Panel be updated to reflect the Q400F in addition to the pax version?
I’m building a Q400 sim so naturally I’d like to see more in the way of a user friendly interface to program inputs and particularly outputs. I am builder, not a programmer. I have been getting by using LINDA for inputs and haven’t started any projects yet with outputs simply because I have no idea where to start with programming those. I definitely appreciate that MJC has opened up the back end for home cockpit users but making that data more accessible via a user interface may make things easier. I plan on upgrading to the training version when it becomes available, so I’m definitely willing to pay for that accessibility. If a user interface is not possible, maybe some tutorials and some expanded documentation on how to access these outputs via UDP / XML might be sufficient.
On the topic of outputs, I’d like to make a functioning Annunciator panel but those individual lights are not included in the outputs. I’ve seen some others mentioning that they would like to have this functionality. Would love to see these outputs.
Not sure of this will be included on the training version or not, but the ability to run the PFD / ND / ED / ARCDU / FMS screens on a networked PC would be amazing for the home cockpit community. Definitely a feature I’d be willing to pay for. Also right now I believe it is not possible to run the left seat PFD / ND at the same time as the right seat PFD / ND. This would be crucial to home cockpit users.
Just a heads up, you project would be more suited for the Cockpit Edition as the TRAINING will not have everything that you desire.
If there is no crossing altitude for a waypoint on an arrival VNAV will maintain the last known altitude at that waypoint. It will do so for every waypoint until it encounters a leg that leads to a waypoint with a new crossing altitude and then probably disconnect because it can't achieve the path or you better hold on tight. It will not continously descend through the waypoints that don't have a specific altitude entered. I'm pretty sure that's what that post was referring to, at least I know that's what has me calculating crossing altitudes manually. As best as I know, currently you cannot select a desired decent angle in the MJC-8 FMS as the poster explains you can in the real one.
-a shortcut key assignment for Left CDU,
-more clear PFD and ND panels in VC...
Santa, what I really, really want for Christmas, is to have the the Q400 send haptic feedback through the direct input api of P3D, to an haptic enabled controller. (aka, force feedback). It would be really cool to feel the effects of flying through turbulence at the yoke. I know this has been mentioned before, many moons ago. Just thought I would ask again to see if that particular option is still on the table. Even as a paid update, would be fine. I know that there aren't many people who have haptic controls.
Cheers, and hope you are all well,
Jax
This feature has been available but is reserved primarily for the professional version sold to airlines at an additional cost.
call me simple. But raindrops and a more HD like virtual cockpit is all I want. PBR exterior would just be an added benefit.
The other thing I forgot to mention that would be nice is a descent banana. would make planning manual descents a tad easier. But this is probably a somewhat major mod
I never flew the Q400 in real life, but given the high level of detail and what’s been simulated by Majestic it may be safe to say that there isn’t a descent banana because its real world counterpart doesn’t have that feature. 😉
For manual descents, the 3 to 1 rule works greats. Plan to be at 10,000 feet AGL 30 miles from your destination. 3,000 AGL 10 miles out etc. you can even put those fixes into the VNAV page on the FMS to get vertical guidance, but if you don’t want to do that Vertical Speed mode and some math work great.
I think I read somewhere that our version uses an older version of the actual software the plane fms uses. I believe the newer real life q400's have the feature. One of the resident RW pilots can correct me
We thank all of you who provided us with ideas/suggestions. We will review the discussions and make a determination as to which items may be feasible contenders for implementation for future updates/enhancements.
Also bear in mind that there are some items that will not be practical/feasible without re-programming some aspects of the systems for which we are not willing to forego further delaying the Q400's tentative release and the further development of the Q300 v2.
This thread is now officially closed.
