Approach stall
lately it happens to me more often that during the transition from a longer approach flown at low speed when deactivating the autopilot the Dash is completely out of elevator trim and then gets into the stall or the other way around crashes into the ground.
What can be the reason ?
This has discussed. Have a look/read and see if some part of the discussion may pertain to your issue.
http://majesticsoftware.com/forums/discussion/151/violent-pitching-crashing-after-autopilot-disconnect/p1
Seems to work!
Thanks a lot.
Conducting a search on the forum in most cases should provide some pertinent information as someone else may have already experienced the issue.
