Problems showing EXT screens - Training edition
Hi!
I'm have moved the efis folder to another computer on my network. I have configured both the main ini file and the efis ini file.
Efis ini:
; UDP 0  CONNECTOR TO FSX SETTINGS
[UDP_CONNECTOR_0]
UDP_ENABLED=1
SEND_RATE_DIVIDER=4
UDP_BROADCAST_ALLOWED=0
UDP_BROADCAST_MASK=127.0.0.1:49260
UDP_RECEIVE_ALLOWED=1
UDP_RECEIVE_MASK=0.0.0.0:49250
; Filter is set to transmit FSI events only
ICP_TX_FILTER=512
Main ini
; UDP 4  CONNECTOR FOR THE COCKPIT APPLICATIONS. This is now set to the EFIS application config
[UDP_CONNECTOR_4]
UDP_ENABLED=1
UDP_BROADCAST_ALLOWED=1
UDP_BROADCAST_MASK=xxx.xxx.xx.xx:49250 (IP to computer where efis folder is)
UDP_RECEIVE_ALLOWED=0
When I run the exe file I just get black screens
Does anyone know what I'm missing here?
R
BTW i have open port 49250 in the Firewall on both pc's
Not sure the logic is the same as for the syspan, but in your EFIS.ini I see UDP_BROADCAST_MASK=127.0.0.1:49260.
Shoudn't "127.0.0.1" be remplaced with your target computer's IP ?
And also UDP_RECEIVE_ALLOWED and UDP_BROADCAST_ALLOWED set to 1 instead of 0 ?
This is how I understand the dual UDP ports communication, but I may be wrong as I have myself an issue with my networked syspan....
Georges
...hmm.. In the documentation it says different
The EFIS application is configured using the mjc84.ini file, located inside the
efis/ini folder.
The file contains configuration entries for the network properties, and the
instrument windows positions.
The following section defines the network properties:
[UDP_CONNECTOR_0]
UDP_ENABLED=1
;SEND_RATE_DIVIDER=0
UDP_ENABLED=1
is a flag, allowing the application to listen on the specific UDP port.
is the line that generally must be left unchanged. If activated, the EFIS
application will attempt to send the data back to the mjc8q400 application.
There is no use for such data at the moment, therefor the default state for this
flag is inactive (0)
In the case if it becomes necessary to enable to above flag, this line identifies
the address and port where the EFIS application will send the data
Activates the data reception by the EFIS application from the mjc8q400 host
application
Identifies the UDP port on which the application will listen.
Main INI file:
In order for the EFIS application to function, it needs the system data from the
host MJC8Q400 TRAINING edition application (Flight Sim addon itself). When
the addon is first installed, it's EFIS connector is not activated. In order to
activate the connector, open the ini/mjc84.ini file, located inside the mjc8q400
folder, and set
[UDP_CONNECTOR_3]
UDP_ENABLED=1
UDP_BROADCAST_MASK=127.0.0.1:49250
Where the UDP_BROADCAST_MASK must be either set to the IP and the port
of the PC where the EFIS application will be running, or 127.0.0.1 if both
applications will run on the same computer, or the UDP mask, and the port if
more than one PC has the EFIS application installed. For more information on
the properties of the connector, please see the Ext UDP Interface specification.
Honestly, I didn't read the EFIS doc before my answer.
But as far as I understand, the 127.0.0.1 IP is used only if the EFIS run on the same computer where the MJC is installed.
In networked configuration I would try
In the EFIS.ini
UDP_BROADCAST_MASK=xxx.x.x.x:49260 where xxx.x.x.x is the IP of the majestic computer installation
In the main.ini (the MJC one)
UDP_BROADCAST_MASK=yyy.y.y.y:49250 where yyy.y.y.y is the computer's IP of your EFIS location
Thanks, for your effort. Still no luck
 But if I understand the docx right, the UDP broadcast mask should be disabled on the efis ini, and the recive mask on the main ini should also be disabled
BTW I have the Cockpit edition not the training edition
Hi renamedia
Boss answer
http://majesticsoftware.com/forums/discussion/1264/training-edition-blank-window-when-using-syspan-on-an-another-computer#latest
might help you to solve your issue
Georges
Thanks! I will try
