Q400 will not accelerate
On attempting takeoff, park brake off, gust lock off, all engine indications showing full power and props at max, the plane barely moves. It is as if the brakes are on, but neither the lever or the overhead warning panel show this to be the case. I would be glad of help.
  • Is this upon every attempt to fly the aircraft?
    Have you had a look outside of your aircraft to see if one of your main tyres are blown?
    If this is not the case it could be that your brakes may not be properly calibrated and are being applied.
  • Make sure if your brakes are controlled in FSX/P3D that you invert them, otherwise the brakes will be applied when your feet are off the pedals.
