Unable to download new version
I bought the Pro version from PC Aviator in March 2020 but the link still seems to be for version 1.20.
How can I get the new version?
Christian
Christian
Try here:
http://majesticsoftware.com/mjc8q400/support.html
Click on "User Area" in the top menu.
I bought my Dash 8 Pro Edition from PC Aviator (Australia) in April 2019, but got the latest v1.024 installer from the User Area mentioned above.
Hi Freddy,
I dont see anything for new version in the user area. Only the link for 1.020 and 1.020b patch.
Christian
Oh.
Well, hopefully the support team replies and gives you a heads up on how to get it then.
Are you running the 32bit or 64 bit version of the Q400?
I'm running the 32 bit version.
Christian
Unfortunately there will not be an update for 32 it users of the Q400 as we stopped updating the 32bit version upon the release of Prepar3D v4.x.
In order to get the new version you would have to be on P3D v4 or v5, and you should be able to purchase the upgrade to the 64 bit version from the vendor from which you purchased the Q400.
