Dash issue with Orbx London City
Please see attached images. The Dash sinks into the ground as shown then bounces and climbs etc uncontrollably. I have the PRO Edition Patch 1020b. Yesterday I purchased and installed the visual extension package which I installed 'over the top.' When I try any other aircraft at this point there is no issue. I have P3DV5.2. I have discussed this with Orbx who have not seen anything like this. The Dash works everywhere else I have tried. I have not flown into EGLC with the Dash for some time so cannot this of anything that I have done recently to cause this. Furthermore, this issue does not occur with default only scenery applied.
Any help welcomed.
Best,
Keith
Thanks to the latest update, this issue is now solved! Well done to the Team!!
Keith
You are welcome.
Thanks for the update , also ENVA(Aerosoft) and LDSP (ORBX) works perfect
