Problem with installing the visual extension after 1.025a patch
Hello!
I have recently installed the 1.025a patch on my computer, and the airplane works fine. However, when I attempt to install the visual extension, I get the warning "This patch can only be installed over the MJC84 versions PILOT or PRO 1.025(64 bit)". I don't remember having had this problem before. Is this because the installer does not recognize the 1.025a version as compatible? (The "a" could be the problem). I downloaded the visual extension from Simmarket just yesterday to ensure that it's up to date. What should I do to install the extension? I would be grateful for help.
Kindly contact us at our Support department via email.
HI, was there a fix for this? Same issue for me. I will mail the support department
Thanks, email us at our Support.
