Blurry displays
Just installed v1_025 and installed visual extension pack.
Right now making my first flight and have noticed that some displays are blurry - FMS, engine display, HGS control panel.
I do not remember having such issues with previous versions.
My sim is P3D5.4, Q400 PRO version
If the problem persists then kindly email our support with the details of your issue(s).
I just downloaded 1_025 from user area, do not know what do u mean by 'correct update'?
There should be a very 1.025a patch as well in your USER AREA. This patch should be installed as well.
But then i cannot install visual enhancement pack, as it says can be installed only up to version 1_025.
Uninstalled 1_025 plus visual pack, and reinstalled 1_025 plus 1_025a ( without visual pack). Now fonts are crispy as they should be
