Crash on startup when using specific Q400 livery
Hey, I am getting the following crash when entering the sim. It only happens with one specific livery (CJC). Other liveries work perfectly. This is after a fresh install of the TRAINING edition. Does the MJC84 control panel write to the aircraft config? Maybe that got corrupt?
Faulting application name: PREPAR3D.EXE, version: 5.4.9.28482, time stamp: 0x6463925f
Faulting module name: ntdll.dll, version: 10.0.22621.2706, time stamp: 0xdd4b5936
Exception code: 0xc0000374
Fault offset: 0x000000000010c7a9
Faulting process id: 0x0x3680
Faulting application start time: 0x0x1DA51A7CD742158
Faulting application path: C:\Lockheed Martin\Prepar3D v5\PREPAR3D.EXE
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 3d02d340-faa6-4bc4-a052-b353f649fc98
Faulting package full name:
Nope, just reinstalled it again, still only this livery crashes.
Eh, nevermind, all the liveries are crashing for me now...
OK, I've further narrowed it down... it's any livery, but it only happens when I spawn at an addon airport. So it's the same problem as https://majesticsoftware.com/forums/discussion/comment/1832#Comment_1832
If I start the sim at a default airport, and then reposition to the aircraft to the addon airport, it works fine.
Have you attempted to un-install the aircraft addon, and be sure to re-install using Admin rights.
