Reinstalling to P3D V5,4
Just a quick one please.
After a bit of a computer update I have reinstalled P3D V5.4. (I have V6 but there are few addons for it, so I went back to V5).
I have Pro V 1_024, 1_025 and 1_025a. Which is the best for V5?
Thanks.
  • Never mind. I won't bother putting it back on again, I have plenty of other good aircraft to use. This one never worked properly anyway.
  • The installer that you get from the vendor from which you purchased the add-on is what you use, and then apply the v1.025a update acquired from the USER AREA.
  • OK, thanks .It looks like I got it from Just Flight, So I install 1.025 into P3D V5, and then the 1.025a update?
  • That is correct. This can then be followed by the latest patch v1.025b
  • OK Thank you.
