Propeller Ground Range
When starting to taxi the propeller ground range reading will sometimes display '12'. What does that indicate? The cockpit certainly gets less loud when I move past it.
According to the Q400 manual: Propeller Ground Range - Propellers are in ground operation range (slightly below FLT IDLE to MAY REVERSE).
More details could be found in the documents at https://www.smartcockpit.com/my-aircraft/bombardier-dash-8-400/
Thanks Reinhard. I'm probably obsessing over something that isn't all that important, but that's me.
