CPAN Engine controls do NOTHING!
Exactly what the title says. The CPAN engine control module does not react when I move any of the controls (levers, potentiometers) on my Saitek yoke and aux control panel. I cannot set the detents on the power levers, and I do not get a reading from the throttles. FSUIPC is turned off, controls are registered in setup. What???!
  • Have you assigned the AXIIS within the simulator itself? Unless you are utilizing the 125Hz controls.
