maintState and maintTimes not created
Hi
Main ini´s are not created on custom liverys. Any tips how to solve this. P3dV5 and Training version
Best regards
Patric
  • Hi @KaptenEk
    Will add this to the list of items to review for a future patch. Thanks for the heads up
  • Could you possibly tell us the folder name for the custom livery. It seem from a code, that Q400 generally should not care if the livery is added or stock
  • I realize this is an old thread. Has there been any update on this issue? I have been trying to figure this one out. Unfortunately, I haven't had much success. Will check back later after another test flight.
    Cheers, Jax
  • Got 'er fixed!
    It's the name of the texture folder(s) for each livery that was causing my issues. (Thanks Boss, your question asking about the folder names, tipped me in the right direction.) I have multiple liveries for Horizon and Air Canada Express. To make it easier to identify which was which, I was using the registry number of the tail of the aircraft as the name of the texture folder. i.e.; (C-GGOY, C- FSRZ, etc.). In order for the maintTimes.ini and maintState.ini to be written, and the failures to occur, the livery texture folder has to be 3 characters. (i.e.; Texture.ACA, or Texture.ACX etc.) A simple mistake which cost me some time and a couple handfuls of hair but my failures are indeed working again.
    Cheers everyone, Jax.
