CPAN Engine controls do NOTHING!
Exactly what the title says. The CPAN engine control module does not react when I move any of the controls (levers, potentiometers) on my Saitek yoke and aux control panel. I cannot set the detents on the power levers, and I do not get a reading from the throttles. FSUIPC is turned off, controls are registered in setup. What???!
Have you assigned the AXIIS within the simulator itself? Unless you are utilizing the 125Hz controls.
I am also having issues with Saitek (Logitech) controls. I can't seem to find a good post or video for setup on MJC Q400.
I have Saitek yoke, rudder/brakes and 2 throttle quadrants. I can get CPAN to recognize my pitch and roll without issue. CPAN seems to ignore the rudder and in the throttle quadrants I get more than 1 slider to active in CPAN when I move 1 lever.
I have all P3D v5.4 control axes not assigned in the P3D control setup.
How does CPAN find my equipment? I must be missing something.
I have figured out that CPAN is assigning both engine to the 1st throttle quadrant lever and both conditions to the 2nd lever. How do I separate the functions?
Still unsuccessful with rudder inputs.
Also discovered, once I got yoke to function that all yoke buttons are non functional?
