Can I operate switches and buttons only via mouseclock?
I have P3Dv4, FSUIPC 5 and Saitek Throttle Quadrants. These have 3 Toggle-switches each and I use them normally to operate the lights, Beacon etc. But in our beloved Dash it does´nt work. I found no way that I can use them, the only possibility is to use the mouse. Pushing such a switch would often be much easier and quicker and would help to reduce the workload. Has someone an explanation or an idea?
Guenther
You could check LINDA, which would connect your hardware to Q400 functions
https://www.avsim.com/forums/forum/424-linda/
I've used LINDA which does work; on a similar note though, is it possible to create a custom script in the .ini file to control LSK keys and specifically to toggle the NAV frequency from STBY to ACT?
