p3d v4 and dash8q400
hello ppl. i have the 64 bit dash. my problem is that control panel dont work. an error message says (its side by side configuration is incorrect). my platform is p3d v4. can anyone help me?
thanks a lot
  • The system panel works fine
  • edited October 2018
    A bit off that the SYSPAN works and not the CPAN (stranger things have happened).
    1. Did you install the Q400 using administrative rights by right clicking on the installer and choosing "Run As Administrator"?
    2. Are you executing both the CPAN and SYSPAN applications using Admin Rights as well?
    3. If the answer is yes to the above questions then I would start by re-installing the Q400 (Be sure to use the Run As Administrator options as this "usually" rectifies most issues.
  • For P3D users if this is happening that is due to the missing or Corrupt Microsoft Sim Connect you can install it from Redist File in P3D Root Folder . Hope it solve the Issue
