"Bank Angle" Warning on startup
Just got the Q400 and trying to figure it out. When I first load up the aircraft at a gate, I get the "bank angle" warning. Have I installed it incorrectly? I am using p3d V4 and have the n64 bit version. Thanks.
Martin
Mine does this in FSX; it's fine. Nothing to worry about.
I get the same thing in FSX. It has not caused any problems
Thank you for the replies. I agree that the "bank angle" thing is not a big deal, provided that I start up at a gate. If I start the aircraft on a runway, I get the bank angle warning, there is a strange whistling sound and the aircraft starts rolling around on the ground. I always start at a gate so it is not causing a big problem, but something is not right. I uninstalled and reinstalled the aircraft, but still have the same issues.
